Pat S Offline OP
My '34 Master coupe will have sidemounts. Therefore no rear spare tire bracket.What goes in the four holes in this case? Agrin
Hi Pat,
You need to talk with a friend of mine, Dave, he is the TA for 33 and 34.
I think you install step head bolts in this location with you have side mounts.
My car is different since I have the trunk and that area is covered up.
Bruce
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
Pat S Offline OP
Thanks Bruce. I finally found a photo of the rear end of a sidemounted car and you can just make out the boltheads through the luggage rack. For a while I thought sidemounted cars had an apron without holes.
Hey Pat,
Do you have a place to get some of these "step head bolts"? If you don't I can get some for you.
Bruce
32 Confederate
Bruce S. DeFord
