CGT Offline OP
I'm looking for brake parts for 1936 chevy pick-up, also rear emergancy brake cable assembly from wheel to attaching steel rod.
you may do better in the parts wanted section hope this helps
on e-bay today is a listing for two rear brake cables for the 36 pick up. indiana location and reasonably priced if the auction doesn't get out of hand. good luck!!
liberty auto 610-277-4730 PA...... EASTWESTAUTOPARTS.COM.....in OK.....northwesternautosupply.com...719-942-3567 in CO maybe some of these guys have it...
Jimmy Carter Clasic Truck Parts ha what you need
Look up on internet. Has on line catalogs
I would like to suggeast that you join the 1936 Chevy Owners forum. They are mostly street rod builders and they pull parts like this off and discard them. Street rod builders are an excellent source of parts for restorers.
