Posts: 168 |
Assuming that points,plugs,condenser,carburetor, are all adjusted properly, can anyone tell me what kind of gas mileage I can expect from my '31 2dr coach?
My speedo is out for repair. However, it seems to me that I'm not getting very good mileage. I've checked ,cleaned,and regapped the plugs. Reset the points, and adjusted to carb. The car starts quickly even when cold. Everything seems to be tuned o.k.
Gotta31 :confused: :confused:
Posts: 168 |
Plugs--.024 points --.018 Plug type -- AC C87 Timing -- Haven't checked. Looking for 6v dwell meter.
Gotta31
Gap your AC-C87 plugs to .040" and set your timing at 18 degrees. You should notice a big difference on power and smoothness at idle. You are looking for a 6 volt dwell meter or a 6 volt timing light? You can use a 12 volt timing light with an auxiliary 12 volt battery.
Posts: 168 |
Okey-dokey!!
I shudda thought about using a 12v batt with the 12v timing light!
Those plugs were gapped pretty wide. Unfortunately I didn't chech them before I regapped them but they were awful wide. Just for my info, why do you recommend setting the plugs at .040?
Gotta31 :eek: :eek:
"You should notice a big difference on power and smoothness at idle." Also, with a wider plug gap you will have a longer duration spark and a hotter spark. And, with today's fuel you will notice a difference in power with the wider plug gap and increased timing. By bumping your timing to 18 degrees with a wider spark plug gap it will eliminate the "popping" out the tail pipe at idle as well.
Posts: 168 |
Thanks buddy!
I'll give it a try tomorrow.
Gotta31 :rolleyes: :rolleyes:
Posts: 86 |
JYD: Would this gap apply to the 1932 as well? I have heard of the 18 degree timing setting.
Jerry Million
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
Posts: 148 |
JYD is that 18* BTDC
Steve
Posts: 116 |
20 MPG??? I would love to get that. I get 11 MPG burning Super in it.
Matt M
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
I get 10-12 mpg with a '31 fire truck with original everything and weighing over 2.5 tons. 15-18 mpg in a car is more reasonable when driving in the 50 mph range. If 35-40 mph then 20 mpg is achievable. If you only get 11 mpg in a '31 then you need to check for fuel leaks or some other problem.
If you have an original early '32 with the 212S carb then 10 mpg is about right. They get 15+ mpg with the later 235S carb.
Posts: 168 |
Hi Fellas: I re-gapped the plugs to .040 and set the timing to 18 degrees BTDC. I got instant results! Much better pick up from a cruise speed and much better fuel economy. I don't know how much better my gas mileage is because I don't have my speedo back yet but going to the same places everyday and watching the needle, I know I'm doing a whole lot better than I was. Thanks to all of you for your suggestions. Gotta31
Posts: 168 |
The 1931 coach that i had gave me 20 MPG on a 150 mile trip that I took it on. that was the only time that I check it. All the other time it was just short runs.
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Bill Barker Previous VCCA CHAT Administrator (VCCA Member: 9802)
Posts: 116 |
Hey Skip, if you go to .045 are there any problems you might have and do you have to change the timing more?
Matt M
Posts: 168 |
Hey JYD -- I'm gonna try that .045 gap. What the hay! If it doesn't work, I can always go back to .040. Hey, how about this little added bit?.....Is there a hotter coil I can safely put on this booger?
Gotta31
