Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I can see that if the switch was in the low speed position and the fan motor was turning very slow or not at all, this could be an unnoticed power drain.
Rich In the low speed position the back of the switch should be the hottest since it's diverting more current from the fan motor and dissipating it as heat. Unless I don't understand, the current drain is the same any time the switch is "on". The difference is how much of that current is allowed to go to the fan motor and how much is bled off as heat.
Sure would have been nice to have written my reply as well as Tiny. Anyway it always amazes me how fast a battery can be run down by a light bulb, radio or other item that will not deflect the ammeter. Guys, seriously, I think it is those GGs that are at work again.
Posts: 415 |
When I got my heater switch, it didn't have a light bulb in it. Does anyone have the numbers on it? Thanks In Advance! __________________________ Joes 37
Posts: 412 |
Joe,
If there is a light inside of my switch, I don't have a clue how to access it.
My switch appears to be a "genuine" part. It has a "H" on the front of the knob and on the support bracket is says "off, Hi, med, low."
Rich
1937 Master Deluxe 4-door Sport Sedan Restoration project 99% complete May never get to 100%
Posts: 415 |
Rich; On mine, the selector knob pull's right off, after a little tug, but the light bulb socket,is inside the switch body. Mine Has "HEAT" on the front of the knob. _____________________________ Joe's 37
Posts: 412 |
Joe,
I gave as hard a tug as I felt was not going to break anything and it did not come off. Mine just has a big "H" on it. I wil get a photo later to send to you.
Rich
Posts: 415 |
Rich; Check for a set screw in the knob,holding it on to the bulb socket. Also, if yours is dark brown in color, it my not have a bulb in it. Mine is a light beige in color. ___________________________ Joe,s 37
Posts: 412 |
Okay, I did go out and attack the switch again. I did get the brown knob off and inside there is a #51 bulb.
I hope that you can find this bulb. I use #44, #46, #47, ect in my radio repairs for dial lights and I know that you can get some of these bulbs from Radio Shack. The #51 is a small bulb with a bayonet mount and it must be 6 volt.
Good luck,
Rich
Posts: 714 |
chev of the 40's has a #51 6 volt bulb. part #115273 $1.25 each if you can't find them at radio shack.
Ken's 1940 Special Deluxe Sedan 1970 Cadillac Hearse
Posts: 415 |
Many thanks guys! I tried both the #51 and #55s, and they were both to small. Have the switch off, and will take it to NAPA and or Radio Shack. ____________________ Joe's 37
Posts: 412 |
Joe,
It is indeed a small bulb, but it does fit down inside of the center of the knob, at least on mine.
Rich
Posts: 415 |
Well, after having a (SENIOR MOMENT),and running to the NAPA stores here, which neither one could find the right bulb, I went to the Radio Shack! They have the bulb! It's not the same number as the #51, but it's the idenical twin. And YES, the #51 does fit right in there too!!!! ___________________________ JOE"S 37
