Page 2 of 2 1 2
Lee Prairie #140651 04/09/09 09:06 AM
75 psi compression sounds pretty low Lee, especially if you just recently had the head redone. I’m sure you are aware of the original specs, 110 pounds plus, and all within 5-10 pounds. Mine runs up around 120 to 130 pounds when I put her away hot and wet. That’s probably because I had the head flattened out when I did the valve job and the little bit they took off brought the compression up a tad.
Don’t discount the fuel that we get today, it is definitely different than the fuel that was compounded back when our engines and fuel systems were designed. I’ve had a stumble in mine since the day I brought it home and a little skip at idle.
My 1950, 3600, 216 runs just fine and dandy when the choke is out a little. Right now I’m running a meticulously rebuilt Carter W-1 carburetor and prior to that, the original Rochester ”˜B’ rebuilt the with the same care. The engine performed the same with both carbs. And contrary to my trouble shooting instinct I then dug into the ignition side of the equation. If the compression was up to snuff and it wasn’t carburetion, then it must be ignition! After all new ignition and once again, a meticulous rebuild of the distributor…..the performance was same ”˜O, same ”˜O! And I run my timing on the ball at idle (500 rpm) and there are no vacuum leaks, (I spent a decade as a vacuum tech before retiring from a national laboratory) and the engine vacuum is steady at around 20inHg.
I truly believe that if I re-jetted the carburetion a step or two richer it would perform as it did when new. However at 14 mpg now, with either the Carter or Rochester, I’m afraid that if I go richer to compensate for the alcoholic fuel that we get, my mileage would drop off to 12 or 13 mpg.
And it’s certainly not going to hurt to re-torque your head, and if you haven’t done it since the valve job, I guarantee you that it needs it now. Watch the breather, if it’s puking frothy greenish gray stuff onto your garage floor after you park it, then that is a purty good indication that the head gasket it leaking some. Might not show up in your oil if it’s just a little.
Denny Graham
Sandwich, IL
While the low compression readings will not cause a miss I would suspect there is another problem. Could be the gauge. I have two different gauges of the same brand and they vary by about 20 pounds. Also the cranking speed of the engine is important. If too slow you will get a lower reading.
Chev Nut #140668 04/09/09 01:03 PM
cranking the engine with the throttle butterfly open or closed will alter readings. the fact it's uniform across the board shows there isn't an indicated problem there
Chevrolet
Valve In Head, Ahead In Value
Dads 31 #140672 04/09/09 02:35 PM
Actually you have not said anything about adjusting the valve lash, or the distributor timing, or that you have checked out the valve timing, the vacuum advance, or whether you did change out the sparkplugs, plug wires, rotor, cap, points & condenser, or the ignition coil. The rebuilding of the carb, did it include cleaning all the circuits in the cast iron base as well as in the pot metal parts of the carb? plugging the vacuum line to the wipers? You may need to take an orderly approach to the problem or problems. Or maybe you are too critical of the engine? You mentioned winding out in low gear and second. Please!..... Don't wind out in low and second, this old long stroke engine only needs to rev up a little in low and second. The torque in high gear is so much more at lower RPMs that there is no need to wind out unless you have a huge load or a steep hill to climb.
MrMack #140677 04/09/09 05:18 PM
He has mentioned most all of the above in previous posts
Chev Nut #140687 04/10/09 12:15 AM
Thanks, Chevnut - MrMack, I have done essentially all the things you mentioned above. The next gas I get will be regular and put in some lead additive stuff that the auto parts store recommended (but I don't have any trouble using 10% ethanol in my tractors (Allis-Chalmers).
I'll re-torque the head bolts asap. Certainly by this coming weekend.
Thank you all for your comments.
Lee Prairie
"It ain't what a man don't know that bothers me, it's what he knows that just aint so", Will Rogers
Lee Prairie #140688 04/10/09 12:32 AM
Gosh, i am glad that you have felt fit to come here to our humble site. We don'r want to seem to be really aggressive about our ideas and advise. We really want you to enjoy the old 49 the way we enjoy our various models of vintage Chevrolets. I know that you had considered makeing all of these changes but was not sure that you were doing them as you went along.
By the way, You won't need to add any lead additive to your 49's tank unless you have really changed the old six with high compression parts, or you will be hauling very heavyloads or a large trailer at near maximium power output. Leaded gasoline isn't required or needed. The only advantage for the lead additives on the shelves is the profit that is made by it's makers and sellers. But don't take my word alone for that, others here will say the same thing....save your money for tires, batteries Etc. and also to pay the registration fees to attend some of the excellent VCCA tours for our vintage Chevrolets. We have fun and we meet some of the finest folks that VCCA has to offer! I am glad to see that you have some of the best built tractors ever put on a farm Allis Chalmers
Have you ever heard of MyTractorForums.com?
Try it.
MrMack #140694 04/10/09 08:17 AM
Mr Mack hit the nail on the head. Lead substitute additive is nothing but a colossal waste of money.
Chevrolet
MrMack #140697 04/10/09 08:58 AM
Mr mack is correct. The 52 has 15,0000 miles on a valve job. Just grinding seats no hardened seats at all. On real long trips I add the recomended amount of Marvel Mystery Oil to the tank as a top lube but that is all. The machinist that did the head advised me NOT to mess with hardened seats on the low compression cool running 216. talk
glyn #140705 04/10/09 09:55 AM
A lead additive is completely unnecessary and the last thing you need.
My 1950 has gone over 50,000 miles (most at high speed) and the head has never been off and I don't use additives.
Chev Nut #140707 04/10/09 10:44 AM
Lead additive is a joke and a total waste of money! Your engine doesn't need it. Lead additive is a gimmick that is sold to naive car dudes just to make a buck.
By the way, how did the timing check come out?
It seems to have been the timing. It is out there purring like a kitten now.
I was dreading the timing, since my experience is with old tractors (Allis-Chalmers) where you time the engine by taking off the inspection plate that covers the flywheel and turn the distributor until the timing marks line up. But it is a lot of 'up-and-down' work because you're on your back on the ground looking at the timing marks in the strobing timing light and you have to get up to access the distributor in most cases.
But, this Chevy can be timed from under the hood. Of course, I read the manual which says to turn the distributor until the ball lines up with the pointer. So I crawled under the truck and found the flywheel cover weep hole and thought... jeepers, I can't see anything through that little hole. Then I looked at the flywheel housing on the distributor side, and once I cleaned away the gunk I saw the viewing hole and pointer.
There is some play in the distributor and the relationship of the flywheel ball to the pointer is very sensitive. I don't know if this is wear or if it is supposed to be that way. But, she's running smoothly now and I'm going for a test (joy) ride now.
Lee Prairie
Lee Prairie #140802 04/11/09 01:18 PM
Glad you finally got it to purrRRRRRRRRRRRRing. We will not stop until you do in getting it to run right. Sometimes it takes a little time to get the gremlins to uncover stuff, put back tools or keep their teensy fingers off those critical parts.
Lee Prairie #140809 04/11/09 03:08 PM
Cool! Glad that you have the engine running correctly. It took us many days and several postings to finally convince you to check the timing. You always start with the easy stuff first and the timing is usually the first thing to check.
Chipper #140813 04/11/09 04:41 PM
I thank everyone who has and is contributing to this discussion and the board in general.
I'm the "Allis-Chalmers guy" that everyone comes to (usually just to shoot the breeze) in regards to their tractors. This is the first Chevy truck for me... I "restored" a 1946 Ford Maxim firetruck, but it only had 3000 miles on it when I got it and so it was essentially a new vehicle. 60 years of passing time had taken its toll, but it didn't need much other than the usual brakes, fuel pump and ignition system.
The Chevy 4400 was (and still is) a working girl with 64,000 miles on her. She lived her life before me on a corn-soybean farm in eastern Nebraska. She only has about 100 miles on the engine overhaul. I would like to get a '48 to '52 half-ton to restore for Sandra. She likes the old Chevy trucks as much as I do. A salvage yard about 2 miles from me just went out of business - they cut up and crushed 15 or so Chevy trucks in that range of years. 5 of them were like mine. I was going to get a few of them, but was too late. Man, I hate to see that happen. History is vanishing before our eyes.
Lee Prairie
But, Dog, I didn't touch the timing. It was running like a little sewing machine when I first got it except that it smoked, fouled the plugs instantaneously and developed a stuck valve (causing a regular miss on cylinder 3). So, I only slowly started suspecting the timing (since the timing seemed to be great before I touched it).
But, when I got it the vacuum hose to the wipers was old, brittle and not connected. My theory is that the previous owner set the timing so that it would run under those conditions. But when I got the wiper motor going and replaced the hose, the timing would have been off for those running conditions. That is the only thing I can think of that would explain everything.
Many thanks,
Lee Prairie
Lee Prairie #140816 04/11/09 04:52 PM
"It is always good to have a planned event come out according to plan, and sometimes I am surprised to have a plan work out."
A hint: I have several old cars with 6 volt systems. I have a very modern timing light that I use on everything with a distributor. I use a 12 volt booster battery to power the timing light. It works lots better than the old timing light that fired the light with the sparkplug, It was so dim I had to close the doors and pull the shades to see the strobe flash. The new light working on the 12 volt booster battery is really bright.
Lee Prairie #140830 04/11/09 08:19 PM
It really doesn't matter if you didn't touch the timing because you need to have a place to start when diagnosing a problem. You were only assuming that the timing was okay, but without checking it you really didn't know, and with some of the changes done to the engine no doubt the timing was affected in the interim. Even when the points are adjusted the timing will change. When working with the type of problems you encountered, don't take anything for granted. Start at the beginning and check everything as you go, and the timing is an excellent place to start.
Again, glad that everything finally worked out for you. Cool!
Page 2 of 2 1 2
