Page 2 of 2 1 2
The later replacement Delco-Remy coil is what you are looking for. It doesn't have the dimple on top or the brass ring on the bottom like the original, but in size and appearance it almost the same. The coil bracket is not spot welded to the coil like the original 1929-32 coil. Instead there is a thru bolt that holds the bracket to the coil. The later coils, like on a 1951 Chevy, will work on a 1929-32, and you can still find some of these Delco-Remy coils on eBay from time to time. yipp laugh laugh laugh
thanks...you say '51, but are there a range of years these were available for that would be what I am looking for?..and any particular numbers?..
ok epi
The Delco coil that you are looking for is number 1115380. There are other aftermaket types that you can use as well. laugh laugh laugh
thanks dog...I'll keep an eye out for one...
ok epi
epi: i have several 380 coils that i'll never use. if ya want one, send me your address and i'll toss it in the mail. mike
thanks, mike...
ok epi
Page 2 of 2 1 2
