#120639 05/08/08 09:04 PM
Where does the wire harness go thru the floor to get to the dash on a 34 1/2 ton ? Should there be hole in the floor board? The wiring is inside the frame when it's below the cab & box but I don't know the correct path in the cab. I'll bet the pickup man will know! I have a new Rhode Island harness to install. Thanks
easymoney
Part of the main harness that mounts up the inside of the cowl enters off the left side of the frame near the toe board and if you look there is an upset channel harness entrance in the upper metal piece of the removal toe board pedal surround close to the steering column just left of the clutch pedal area.
