#489374 02/02/24 12:53 PM
Jonjet Offline OP
Don't know if I've asked this question before but has anyone ever restored the inside visors for 33-35"s? I did it many years ago but am not sure how I did it.
Jon T.
Jonjet #489376 02/02/24 02:52 PM
Jon,
My memory says that 1933 visors are grained, embossed cardboard. 1935 visors are smooth masonite with wrinkle paint. I don't know about 1934.
Jonjet #489377 02/02/24 02:59 PM
Jonjet Offline OP
M 35 Master Visors are smooth masonite with wrinkle paint but my 35 Standards are not. There is some question to weather they are correct but I think they used both on 35 Standards. 34 are the same as 33's.
Jon T.
Jonjet #489388 02/02/24 08:36 PM
Attached is a picture of the lefthand visor on my 34 Master that I believe to be original. Mike
Jonjet #489391 02/02/24 09:40 PM
That is a 1934 Master visor.
Jonjet #489393 02/02/24 10:03 PM
Jonjet Offline OP
You are correct Mike, now how do I duplicate that pattern?
Jon T.
Jonjet #489395 02/02/24 10:08 PM
I think that is also a 1933 visor. I think I have one somewhere.
Jonjet #489396 02/02/24 10:10 PM
Jonjet Offline OP
You are correct also Mike.
Jon T.
Jonjet #489399 02/02/24 11:29 PM
I wanted to duplicate 41-48 heater knobs that weren’t available. I saw this video by Aluminite and tried it with very good success.
Using the same process, I would think you could make a mold from a visor that still has good detail, cast replica visors from resin, and either paint or color the resin as required.
Here are a couple pictures of the knobs that I cast. The detail surprised me. I used nothing more than a Dixie cup for a mold container.
Jonjet #489427 02/03/24 09:36 PM
Jonjet Offline OP
I'm not wanting to make new Visors. I have many of them. I just need to recreate the pattern on them and then paint them. I think what I did before was make a mold and then paint the Visors with Primer. Before the Primer dried I ''stamped'' the Visor with the mold I made. But when I try it now the primer sticks to the mold and does not look right.
Jon T.
Jonjet #489428 02/03/24 10:17 PM
THH Offline
Hey Minetto -- great video. Thanks for sending that. Much appreciated.
Jonjet #489437 02/05/24 02:19 PM
Left and rights available. Not able to provide a photo. I will send to John, maybe he can add photos.
Jonjet #489440 02/05/24 03:32 PM
Jonjet Offline OP
Wes, I'm working on posting the pictures now.
Jon T.
Jonjet #489441 02/05/24 03:50 PM
Jonjet Offline OP
These are the pictures.
20240205_114601_resized.jpg 20240205_114601_resized_6.jpg 20240205_114611_resized.jpg 20240205_114611_resized_5.jpg 20240205_114629_resized.jpg 20240205_114629_resized_7.jpg 20240205_114636_resized.jpg 20240205_114636_resized_4.jpg
Jon T.
Jonjet #489443 02/05/24 08:09 PM
The following info is what I believe to be accurate, from what I have learned in the past 50 years.
The embossed ones are '33/'34. The plain flat ones with 4 square(ish) corners are 1935 Master and Standard. The smaller plain flat with 2 round corners are '36 Standard, maybe Master too. I don't know.
35Mike #489447 02/05/24 08:46 PM
The 1936 Master visor is cloth covered.
Jonjet #489452 02/06/24 12:07 AM
Jonjet Offline OP
Thanks Mike, you are 98% correct. The 35 Genuine Accessory Broc. shows both embossed and plain flat for 35 Standard. And of course Gene is right as always!
Jon T.
Jonjet #489462 02/06/24 09:48 AM
Jonjet Offline OP
Now that I've beat that horse to death I still haven't figured how to get the embossed pattern on the 33-34 Visor?
Jon T.
Jonjet #489463 02/06/24 10:33 AM
Find someone with a programmable router that can cut the pattern. Then have a program duplicating it. Or you can do it by hand?
