VCCA Home
Posted By: Jonjet 33-35 Sunvisors - 02/02/24 04:53 PM
Don't know if I've asked this question before but has anyone ever restored the inside visors for 33-35"s? I did it many years ago but am not sure how I did it.
Posted By: 35Mike Re: 33-35 Sunvisors - 02/02/24 06:52 PM
Jon,
My memory says that 1933 visors are grained, embossed cardboard. 1935 visors are smooth masonite with wrinkle paint. I don't know about 1934.
Posted By: Jonjet Re: 33-35 Sunvisors - 02/02/24 06:59 PM
M 35 Master Visors are smooth masonite with wrinkle paint but my 35 Standards are not. There is some question to weather they are correct but I think they used both on 35 Standards. 34 are the same as 33's.
Posted By: minetto Re: 33-35 Sunvisors - 02/03/24 12:36 AM
Attached is a picture of the lefthand visor on my 34 Master that I believe to be original. Mike
Posted By: Chev Nut Re: 33-35 Sunvisors - 02/03/24 01:40 AM
That is a 1934 Master visor.
Posted By: Jonjet Re: 33-35 Sunvisors - 02/03/24 02:03 AM
You are correct Mike, now how do I duplicate that pattern?
Posted By: 35Mike Re: 33-35 Sunvisors - 02/03/24 02:08 AM
I think that is also a 1933 visor. I think I have one somewhere.
Posted By: Jonjet Re: 33-35 Sunvisors - 02/03/24 02:10 AM
You are correct also Mike.
Posted By: minetto Re: 33-35 Sunvisors - 02/03/24 03:29 AM
I wanted to duplicate 41-48 heater knobs that weren’t available. I saw this video by Aluminite and tried it with very good success.
Using the same process, I would think you could make a mold from a visor that still has good detail, cast replica visors from resin, and either paint or color the resin as required.
Here are a couple pictures of the knobs that I cast. The detail surprised me. I used nothing more than a Dixie cup for a mold container.
Posted By: Jonjet Re: 33-35 Sunvisors - 02/04/24 01:36 AM
I'm not wanting to make new Visors. I have many of them. I just need to recreate the pattern on them and then paint them. I think what I did before was make a mold and then paint the Visors with Primer. Before the Primer dried I ''stamped'' the Visor with the mold I made. But when I try it now the primer sticks to the mold and does not look right.
Posted By: THH Re: 33-35 Sunvisors - 02/04/24 02:17 AM
Hey Minetto -- great video. Thanks for sending that. Much appreciated.
Posted By: wesb Re: 33-35 Sunvisors - 02/05/24 06:19 PM
Left and rights available. Not able to provide a photo. I will send to John, maybe he can add photos.
Posted By: Jonjet Re: 33-35 Sunvisors - 02/05/24 07:32 PM
Wes, I'm working on posting the pictures now.
Posted By: Jonjet Re: 33-35 Sunvisors - 02/05/24 07:50 PM
These are the pictures.
Posted By: 35Mike Re: 33-35 Sunvisors - 02/06/24 12:09 AM
The following info is what I believe to be accurate, from what I have learned in the past 50 years.
The embossed ones are '33/'34. The plain flat ones with 4 square(ish) corners are 1935 Master and Standard. The smaller plain flat with 2 round corners are '36 Standard, maybe Master too. I don't know.
Posted By: Chev Nut Re: 33-35 Sunvisors - 02/06/24 12:46 AM
The 1936 Master visor is cloth covered.
Posted By: Jonjet Re: 33-35 Sunvisors - 02/06/24 04:07 AM
Thanks Mike, you are 98% correct. The 35 Genuine Accessory Broc. shows both embossed and plain flat for 35 Standard. And of course Gene is right as always!
Posted By: Jonjet Re: 33-35 Sunvisors - 02/06/24 01:48 PM
Now that I've beat that horse to death I still haven't figured how to get the embossed pattern on the 33-34 Visor?
Posted By: Chipper Re: 33-35 Sunvisors - 02/06/24 02:33 PM
Find someone with a programmable router that can cut the pattern. Then have a program duplicating it. Or you can do it by hand?
