Posts: 107 |
I know there are places i could have bought these. but i like to tinker,so tried my luck to make my own. THIS WILL ONLY WORK ON SHIMS LESS THAN .004... I took an cheap 1/4" socket and drill out where the nut goes with a 21/64 drill bit , then grounded down the outside to a tapper end.. when i need a shim i put this sharp end on a shim stock sheet and twist it around like a cookie cutter. do this with a soft piece like a tire on the back side of the sheet...then cut out the outside edge shape like the cap.
carson told you this!!
Posts: 107 |
I found out it worked better to use this home made tool like a cookie cutter rather than hammer it on a block of wood.. also making the hole first is better too... IF you try this you may find a better way ,this was just tinking around ,and it works ok for me.. GOOD LUCK TO YOU
Posts: 11,162 |
36 nut, I bet you have a unique way of cutting the holes in donuts before you roast them on a stick! Ha! Ha! good show! (He probably has ever one of that pile of frogskins he started out with too!) And good luck, your self....Carson!
Posts: 689 |
I use a similar process to punch holes in gasket material when I make new gaskets. With this method you can make just about any size hole, from 1/4" up to nearly 1/2". Just take a steel golf club shaft (free at any pro shop or garbage can at your local course!) and cut with a hack saw or plumbers tubing cutter. Then use a small round file or Dremel tool with a rotary bit and taper the inside diameter to a sharp edge. Use the cutter in a cookie cutter fashion to cut holes. Thicker material can also be cut by tapping on the unsharpened end. A bolt fit in the unsharpened end can be used as a striking head. I've made a set of 3 or 4 for common hole sizes. The golf shaft steel holds a good edge and is easy to resharpen.
Posts: 11,162 |
Or...Why not just spend less than $5 to buy a 9 piece set of gasket hole punches, harbor Freight has a set on sale as we chatter....
Posts: 959 |
Posts: 291 |
not only that, Macky, but you get to keep those 5 frog skins!!!!!!
Dan.
Together we can do anything. The impossible just takes longer.
Posts: 11,162 |
Yes, then if you live here in Texas With the fiver you can go to a Quick-Stop and buy either a couple gallons of gasoline or a pack of cigarettes and a cold beer! ..... OH, I almost forgot a lottery ticket with five chances at the big jackpot!
On the other hand where did I put that Harbor Freight sales catalog?
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
Now, if you used mertric sockets to make the punch forms, the planet would be better off without them!
