making your own rod shims - 11/02/04 09:38 PM
I know there are places i could have bought these. but i like to tinker,so tried my luck to make my own.
THIS WILL ONLY WORK ON SHIMS LESS THAN .004...
I took an cheap 1/4" socket and drill out where the nut goes with a 21/64 drill bit , then grounded down the outside to a tapper end..
when i need a shim i put this sharp end on a shim stock sheet and twist it around like a cookie cutter. do this with a soft piece like a tire on the back side of the sheet...then cut out the outside edge shape like the cap.
