I've used a K&N electric fuel pump for 4 or 5 years now with no problems what so ever . No more vapor lock or
long cranking times in the hot summers here in Arizona.
omotive Motorcycle & ATV All
K&N Universal Inline Fuel Pumps
K&N Universal Inline Fuel Pump 81-0401
Compatible with diesel, biodiesel, gasoline, E85, methanol, ethanol, alcohol and other fuels
Universal design fits most applications
Self-priming design provides a quiet running volume
Eliminates vapor lock and flooding
Fuel filter and installation hardware is included
Inline Fuel Pumps
K&N Inline Fuel Pumps provide premium quality fuel system hardware with a universal design that fits a wide variety of applications. Compatible with most fuels, this self-regulating 12-volt pump helps prevent vapor lock and flooding.
K&N Universal Inline Fuel Pump 81-0400
K&N 81-0400 universal inline fuel pump is engineered to pump 15 gallons per hour between 1 and 2 psi.
K&N Inline Fuel Pump 81-0401
K&N 81-0401 universal inline fuel pump is engineered to pump 25 gallons per hour between 1.5 and 4 psi.
K&N Inline Fuel Pump 81-0402
K&N 81-0402 universal inline fuel pump is engineered to pump 32 gallons per hour between 4 and 7 psi.
K&N Inline Fuel Pump 81-0403
K&N 81-0403 universal inline fuel pump is engineered to pump 34 gallons per hour between 7 and 10 psi.
Good Luck !
