Posts: 102 |
I pulled the engine/trans, from my 36 standard sedan, to deal with a knock. Before I did that I checked the differential level and it was way over full. So the trans oil leaked into the differential. The parts book lists a washer/seal # 474921. It looks to be behind the front bushing. So far the only thing I can find online is a C-36-S NOS "Okie" drive bushing assembly. It has a seal in it. $90 on epray. Is this the proper replacement item for this 474921 seal?
It looks like the bushing comes out to get to the seal. And the u-joint shaft is a bit rough so I put in a $35 bid on one.
I did research the forums but did not find much. Thank you for any assistance,
Steve S
The 1936 Standard front and rear bushing and seal fit that model only. There is not an Oakie type bushing made today for a FC. The seal was only a ring of cork. Perhaps some one will reply that found a real seal that will work. If it were mine I would try to get the old stock Oakie bushing and seal you mentioned if it is for an FC.....
Posts: 102 |
Thank you for the fast reply Gene.
I went ahead and bought it. Says it is for a FC. I just hope the seal is still pliable. Thanks again,
Steve S
That should come with a more modern seal If it has grown old and hard will still be a good sample for size.
Posts: 1,478 |
To revive old stock cork seals. Place in hot water. Watch carefully as the cork rejuvenates. It will expand to the correct size; however, it will keep expanding if not removed from the hot water. The cork seals that I rejuvenated did work just fine.
Posts: 271 |
Modern lip seals are readily available from bearing supply shops for the 1933-35 Standards so if you give them the inner and outer dimensions chances are they may be able to help.
RonDaw
