Torque tube leak - 12/19/18 10:58 PM
I pulled the engine/trans, from my 36 standard sedan, to deal with a knock. Before I did that I checked the differential level and it was way over full. So the trans oil leaked into the differential.
The parts book lists a washer/seal # 474921. It looks to be behind the front bushing. So far the only thing I can find online is a C-36-S NOS "Okie" drive bushing assembly. It has a seal in it. $90 on epray.
Is this the proper replacement item for this 474921 seal?
It looks like the bushing comes out to get to the seal.
And the u-joint shaft is a bit rough so I put in a $35 bid on one.
I did research the forums but did not find much.
Thank you for any assistance,
Steve S
Steve S
