Posts: 61 |
Lately, like the last 6 months, I have made little progress and little time to drive the 1930, 2 door coach.
When I start the vehicle on a regular basis, say 1 or 2 times a week, it starts fine, without too much trouble. But when it is longer, the car now coughs and spits and coughs some more as I try to find the correct amount of gas to give it. It did not use to do this. Any suggestions?
I started the car and drove it 2 miles yesterday so I will soon go back and see how it is.
ON A DIFFERENT TOPIC, I took my axel/grease cap covers in to be chromed. I had 2 that matched and 2 other that were different. I felt the price for all new ones from the FS was more than I wanted to spend at this point. During the chroming process, the small disc (nickle size) in the center on one cap fell out. I am looking for a used one that someone may have and be willing to part with.
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
My best guess is that something is going on with the float bowl of the carb. There is possibly dirt in there that settles when the car sits for more than a week and it partially plugs the jet.
Or the fuel is leaking out and there is not enough fuel in the carb to keep things running until after the fuel pump catches up.
You might want to try this test the next time you start the car after it has been sitting for more than a week. Before you turn on the ignition run the starter 3 or 4 cycles of about 10 seconds each. This will run the fuel pump and make sure the float bowl is filled. Then set the choke and hand throttle, turn on the ignition, and hit the starter.
Let us know what happens.
Posts: 1,894 |
In addition to the suggestions above - How old is the fuel?
It will start to degrade after a month or so and get worse as it ages, possibly causing problems sooner if there are any other weak engine components like points/condenser/plugs/coil.
Posts: 61 |
THANK YOU for the excellent comments. I did start the car today after starting yesterday. I DID still have some of the coughing, sputtering and reluctance to start and run smooth. (I used to not have this...but I am repeating myself)
Yes, the gas is old, over 2 months. But I do add fuel stabilizer, always. ( I understand there are mixed reviews of STA-BIL.) BUT, I did add 3-4 gallons of new gas over the last 2 days.
Today, I also drove the car a couple miles to "move" fuel through the lines and incorporate my new fuel.
Posts: 1,894 |
2 months is still quite good so suspect other areas causing the issue as above.. I've had no issues with Stabil over the last 20ish years and use it in everything that sits.
Posts: 61 |
Rusty.
I did try your method today. I feel like it improved the starting today. There was less of the coughing and rough starting/running. Monday should be a better test as I will not drive the car for 3 days.
As for the STA-BIL, I recall that Napa had 2 types of the product. Good and better!!!!!!!!
Thanks to all.
Posts: 61 |
Well, I started the car on Weds., the 23, after 4 days off. It took 3-4 minutes before the car started to run smooth. I tried the method Rusty suggested again. I guess the carb. needs some attention.
Most of the gas in the tank is very fresh so that should not be the issue.
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
wondering ? is there a leak somewhere, say an air leak, so that when it sits, the fuel slowly drains back out the carb & line ??
Posts: 61 |
This is a test. I just wrote a current update and it disappeared. So I am going to retry to see if I am doing this correctly. Thank you.
Posts: 61 |
OK, I STILL HAVE THIS STARTING PROBLEM.
Yesterday I replaced all the old fuel. cleaned the bowl of sediment. blew down the fuel line BACK to the tank. I blew forward to the Carburetor. I put in 3 gallons of new fuel. NOW, the fuel WILL NOT pump forward and fill the glass filter bowl. Of course, the reason I blew down the lines wasn to clear the old fuel as much as possible. Yes, before I did this, the fuel pumped to the bowl.
WHAT DID I DO?
Posts: 61 |
Hi J D.
I have seen your posts b4 and I know u are trying to help. thanks. the fuel is not getting to the carb. The fuel is not even getting to the glass bowl/filter. Yesterday, it did. The glass bowl/filter has the rubber gasket in. How can the glass bowl suck air? Why?
Posts: 197 |
If the bowl isn't properly seated in the pump it won't pump or if it does pump it'll leak like a sieve. Don't ask how I know.......
And, to add to the above, the rubber bowl gaskets tend to suck air. I only use cork bowl gaskets for that reason. the fuel is not getting to the carb. The fuel is not even getting to the glass bowl/filter. If that is the case then the problem is either your fuel pump or the problem is located between the fuel pump and the dip tube inside of the gas tank. I would start with the fuel pump. Remove the fuel pump from the engine and manually check it to see if it is pumping as it should. If it isn't then the problem is with your fuel pump.
Posts: 61 |
thanks.
I will check these out next week.
but wasn't I sent the rubber gasket by the FS? funny. I forgot about it and d/n see the rubber gasket yesterday, but today I did. could I have it in the wrong location?
Posts: 61 |
When i wrote my comment i was talking about the fuel BOWL/FILTER container. I think I am confusing everyone.
I recently rebuilt the Fuel Pump on my 1929: 1929 Fuel Pump Rebuildyou could also disconnect the fuel lines on the Fuel Pump and use a vacuuum/ pressure gauge to test to see IF the pump is sucking/ pumping fuel !! and IF you blew air into the fuel pump might have unseated or ruptured the diapragm !! and I have the rubber gasket on my fuel glass bowl on fuel pump with the screen and drop in filter, and pumps great.
When i wrote my comment i was talking about the fuel BOWL/FILTER container. I think I am confusing everyone. Yes you are. When asking questions be as specific as you can so that we will know exactly what you are talking about. We assumed that you were talking about your fuel pump. At any rate in your last post you mentioned the "fuel BOWL/FILTER container". Are you referring to the glass bowl and the wire mesh filter that is on the fuel pump or are you talking about an additional fuel filter that you have installed at another location in your fuel system?
Posts: 424 Likes: 6
Posts: 424 Likes: 6 |
Someone once stated "a picture is worth a thousand words.........". It might help.
Jon.
Posts: 734 Likes: 14
Posts: 734 Likes: 14 |
Hello Bauer, By blowing air thru the fuel line/lines to clear away old fuel, I think that there would be no fuel available to "prime the pump" as they say. Putting fresh fuel in the fuel tank may not migrate, by itself, over to the fuel filter/bowl/pump assemblies without a little help. Try removing the glass bowl and with low pressure, force fuel in the fuel tank thru the line. When fuel flows to the filter, fill the glass bowl with fresh fuel and install glass bowl correctly. Disconnect fuel line at carburetor and again apply low pressure at fuel tank for a short time. You may or may-not get fuel to run out at the end of the carb line. The object is to force some fuel to the pump so that it can do it's job. Verify that the pump is working by cranking the engine starter (ignition OFF) a few revolutions and looking for fuel to flow out the carb end of the line. If NO fuel or little fuel flows, suspect fuel pump issues. If good flow, reconnect fuel line to carb and continue to investigate engine running concerns. Check that your fuel cap breather is not plugged up. Be safe around fuel. Good Luck.
Posts: 98 |
Have you checked the check valves in your fuel pump. The check valves are located on the large diameter end of your fuel pump towards the front of the engine. As you look at the fuel pump from above you will see two hex head "bolts" if you will on either side of the diaphragm chamber. Remove those and take care not to bend the fine wire springs which are under them. The springs in combination with the discs that are under them are the check valves. Their purpose is to stop the flow of gasoline backwards out of the fuel pump. They can be damaged by forcing air thru the pump. I learned that by experience. When reassembling the check valves take caution to get the springs in place properly. If the are damaged in one manner or another you will need to order a fuel pump rebuild kit. Filling station has them available and I'm certain there are other vendors as well. The rebuild is not difficult. Take your time and pay close attention as you dismantle your pump. It isn't difficult and most anyone with mechanical aptitude can perform the rebuild.
Don't let a day go by that you don't attempt to learn something new.
Posts: 75 |
Try this take the gas cap off, cover the filler hole with your hand and take a air hose and blow it in the tank stick the hose between your thumb and keep the seal. it will fill the bowl and get to the pump Short bursts of air. Worked for me on a new tank and fuel lines. I disconnected the fuel line at the fuel pump going to the carb, put a pan underneath it and you will hear it come out into the pan or get a helper. Then hook up the line and do the same procedure and it will fill the carb.
