Page 2 of 5 1 2 3 4 5
So i made the rocker panel from three sheet pieces - so I could handle it better - and weld them together for the best fit. After this I made the holes for spot welding
Then I had to install the brackets for running board. After several test I fixed the right position and weld them with a welding clamp
Greetings André
1940 Special de Luxe Sport Sedan
https://1940specialdeluxe.wordpress.com
Most of the threads to mount the running boards are damaged. So I had to drill them out and insert threaded rivets.
Some holes were no longer present or heavily corroded, so I had to replace them or drilling new ones
Finally, after one week work, I could weld the inner Rocker panel. Only to 30% at this time, but next will do the other 70% and then the right site is done - I hope. Stay tuned
Greetings André
Andre
You have done a good job on the panel replacement, you seem to have had some training in metal shaping or panel beating.
Hi Andre,
You are doing a fine job. Thanks for documenting your work so others can understand the process. Until you have worked through replacing severely damaged body parts, especially with rust damage, you have no idea of the finer steps in the process. Welding is so sensitive to the amount of heat used to keep parts from distorting. You also have to be well aware of what areas are so week from rust that they can not be welded. A lot of patience, imagination, Origami, and refitting to get thinks right.
As seen in some of your pictures (red painted areas) it is important to use a rust sealer under your work to protect as much of the old and new metal as possible.
Keep up the good work,
Mike Buller
Amazing work Alligator !!!! Thanks for all the picts.!!!!!
David Martin-Hendersonville NC, Pine Island Fl....... 1940 Chevy SDSS,
Thanks for the positive Feedback. Yesterday could do some more Work on the Chev and get the Inner Panel closed.
After this, i realised that there was something missing at the behind fender to install the Frame Console
Greetings André
Yesterday finshed the work on the right inner panel (I hope). Prepared with rust sealer and sealing compouned i could weld in the last part
On the left side i began to cut out the bad parts
Greetings André
Your idea of rust prevention after each step is good but I have found that welding the next piece in removes the preventative and also this material can smolder for a long time and then flare up when you least want it to (I destroyed 1 truck that way).
tonyw #376647 10/10/16 06:02 AM
Hello Tony,
Yes, you are right with your hint, but after welding I could not go to this place anymore and without protection I did not want to close it. For Security I stay in the Garage after Welding two or three Hours
Greetings André
The 2 or 3 hour wait is good, I waited 15 or 20 minutes then 30 minutes later the neighbours were calling the fire brigade.
tonyw #387302 04/09/17 10:56 AM
In October I worked a few more days on the car, but then it was too cold. Now 6 months later the weather is better and the temperatures in the garage are much better for working on the Chevy. Here are some pictures from work. The newest Pictures are on top.
Next week I will bring the framework to dry ice blasting. I'm already looking forward to the result. When assessing the frame, I noticed that a mounting point is not identical with the opposite one. Is this correct?
Left Side / First three Pictures - Right Side / Last two Pictures
Greetings André
No one any idea why they are different or if this is correct?
Greetings André
I CAN SEND YOU SOME FACTORY PICTURES OF THE FRAME BUT WOULD NEED YOUR EMAIL ADDRESS TO DO SO
GENE SCHNEIDER
André
The right side mounting bracket is correct. It is the same as my '40. It uses the same mounting pad as the left side does. When I replaced my original pads some 20 years ago, the original right and left pads (cushions) were identical to each other.
I do not know why they are different.
Hmm, a special thing from the RHD??
Greetings André
News from the Frame. Looks fine.Here are Videos before
and after
Ice Blasting
Greetings André
Now the Frame is painted and i put the Chassis on it for a Test. I´ve bought the Body Mounting Pats from Chevs.
I´ve counted fourteen mounting places on my Frame, but in the set are much more pads. Left you see the needed and on the right side the remaining Pads. Are the rest, because they fit also on other models, or did I forget them somewhere ?
Greetings André
Hi Andre,
Always exciting to see what you have done and the degree of professionalism you show with each repair. The 4 pads on the right side of your last picture are pads used for mounting the radiator. You are correct that some of the pads are extra and not needed. I did not use all four of the radiator pads. I used only the wider middle pad and used a metal shim with it. The shim I made was in the same shape as the wide rubber pad.
Best wishes always,
Hi Mike,
thank you for the praise. Next week will get back my engine, than i will have a look by mounting the radiator. Another questions about the chassis shims. How will i see if the chassis is on the right level. It's not a lightweight and will press down on the frame anyway, or not? Did not look for this in the manual yet
Greetings André
Hi Andre,
In the best case senario you didn't have any shims when you removed the body from the frame just the rubber pads were there. If you have not done any body work to the areas were the pads are installed then everything should go back with no problem. You do want to checkout how well the doors align before and after you tighten the body to the frame, and should assume any area where the frame is not pinching the pads should require shimming. I let my body sit on my frame with the pads installed and the bolts in place but not tightened for awhile (a couple of weeks) and did other work. I assume an over night wait is plenty and then tightening everything gradually (same torque) to watch if the door alignment changes. I had replaced the ends of my floor braces on the passenger side and the bottoms of both firewall braces. Only the firewall braces needed extra shimming.
Good luck, Mike
P.S. SEARCH results on Bolting Body to Frame
Thanks Mike, than will do this way and see what happens
Greetings André
Hi - Yes, I'm still at work on my 1940 Chevy. A Prolonged Illness has set me back in my schedule, but now I'm back.
As I said, in June 2017 get back my, again refurbished, Engine. More on this Thread
https://vccachat.org/ubbthreads.php/topics/344166/4.html
The above described Chassis mounting Test was, to find the right position of the brackets I´ve forgot to weld on the inner panel.
Next I had to remove the complete wiring harness, because the cable sheathing was broken everywhere and the cables had contact with each other. So it is necessary to make a new W.Harness
Next Project, was the Firewall, were I have to disconnect the whole foot pedal linkage, to clean it. On the passage from Firewall to Footboard, did some Body sealant and put Owatrol Oil on the sheet, for better Rust prevent. Over this I paint 2-3 layer Ovagrundol
In this Thraed https://vccachat.org/ubbthreads.php/topics/387523/harrison-heater-mount.html talked about cracks in the firewall from Heater Mounting. To repair this, I weld sheet metal from the inside and than I weld the Cracks from outside. First Try´s with braze the cracks did not work
Greetings André
Dobble Post?!
Greetings André
Finally, after two Years, now the Time has come, to do new Paint on the Underbody. But first hard work to remove the old one.
3 Layers Overgrundol and then 2 Layers Chassislack O.H. That looks great cool
More Pictures you can find under https://flic.kr/s/aHskUTUqs5
Greetings André
Wow. Mucho work that was wonderfully done!
Congrats, Dean
