from your supplied information, believe the serial number
2..........is factory where it was made, Tarrytown NY
CA.........is symbol for a 1933 master series
05.....would be month it was made...May
5 window coupe.." special coupe with trunk" fisher model 35567
as far as the steering box goes, you should be able to purchase a SECTOR SHAFT "new old stock " on ebay usa or putting a **parts wanted ad*** in that section here. Same goes for a complete column assembly
appears both of us were typing response at same time.
mike lynch............
