Hi,i'm new here and from Belgium,my Englisch is not good,therefore the for text sometimes a bit weid.
I have a 1933 Chevrolet 5 window coupe bought and would like to have some information about correct model and motor.
chassis nr 2CA 0552201,this is now a master of a eagle,according to us papers of import is it eagle ?
Engine nr 836915,this would be the original ingine 206 engine now ?
Also a quick question if there is in the us a reproduction steeringhouse exists for for this model,or a steeringbox which also fits on this model ?
Are those 206 engine is turning is still found in the us ?
Here in Belgium i there is nothing to find spare parts or info on this model.
Welcome to Chevy Chatter! Glad to have you with us!
According to the serial number that you posted, your 1933 series CA Master was built in Tarrytown, New York in May of 1933. It was the 51,201st vehicle built in that factory (serial numbers started at 1,001).
Regarding your engine casting number of 836915, your engine is for a 1933 series CB Master Commercial.
from your supplied information, believe the serial number
2..........is factory where it was made, Tarrytown NY
CA.........is symbol for a 1933 master series
05.....would be month it was made...May
5 window coupe.." special coupe with trunk" fisher model 35567
as far as the steering box goes, you should be able to purchase a SECTOR SHAFT "new old stock " on ebay usa or putting a **parts wanted ad*** in that section here. Same goes for a complete column assembly
appears both of us were typing response at same time.
mike lynch............ Agrin
The Master replaced the Eagle in March of 1933. The tag you got the 2CA05 from should say Master being it was made in May 1933...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
Thanks you for the quick response.
Does anyone know exactly how many were made of this model?
60,402 1933 2 passenger 5 window coupes.
