VCCA Home
Posted By: bigpine38 which fan belt 1948 216 ci motor - 10/12/16 07:30 PM
went online some said 41-1/2" some said 43" ?? stock gen and water pump..sc
Posted By: Chev Nut Re: which fan belt 1948 216 ci motor - 10/12/16 08:13 PM
The 1937-1952 fan belt, GM part #3680776 is 5/8" wide and 41 1/2 long at the pitch line.
Dayco #23425, Gates # TR 20426
Posted By: bigpine38 Re: which fan belt 1948 216 ci motor - 10/13/16 04:29 AM
Thanks much.sc
Posted By: chef-chevy Re: which fan belt 1948 216 ci motor - 10/13/16 08:28 PM
So Gene, are the belts you posted still available???The only one I can find have teeth
Posted By: Chev Nut Re: which fan belt 1948 216 ci motor - 10/13/16 10:14 PM
The last belt I got was from NAPA and was smooth.
Posted By: chef-chevy Re: which fan belt 1948 216 ci motor - 10/13/16 10:36 PM
I will try that
Posted By: Back Roads Re: which fan belt 1948 216 ci motor - 10/13/16 11:28 PM
What do you not like about a belt with notches? Are you having your car judged?
Posted By: ChevyGuru Re: which fan belt 1948 216 ci motor - 10/14/16 01:35 AM
The notches / teeth in a belt just look wrong - too modern. Like seeing a universal upper radiator hose with the accordion look, just jumps out as you as wrong.
Posted By: chef-chevy Re: which fan belt 1948 216 ci motor - 10/14/16 01:55 AM
Back roads...judged..yes..I have 2 with the teeth I need a back one that looks correct
Posted By: Chipper Re: which fan belt 1948 216 ci motor - 10/14/16 03:14 AM
I buy my fan belts at my local hardware store. They are fractional horsepower belts that have proven to last many years. Can't remember the last one that failed. Much less expensive than belts sold at auto part stores. They are smooth as well.
Posted By: chef-chevy Re: which fan belt 1948 216 ci motor - 10/15/16 08:17 PM
Thanks Chipper I will try that out
