That's what I thought. It is very rudimentary. Interestingly, the bulb still works! It is an 1132, 27CP and is quite bright. The back of the reflector (outside) was so corroded I couldn't tell what it was so I bought some brass paint and painted it after cleaning it real well. I also polished the inside of the reflector. It still had some original cloth insulated wire. To attach the wire, you unscrew the back of the switch and that exposes two small set screws. You just put the ends of the wires into a couple of holes, tighten the screws, put the switch back together any you are ready to go. This was in a box of junk someone gave to a friend of mine and he gave it to me. Beamer
O man those things are very-very rare and are worth thousands of dollars in there original state.
But once they are messed with (like
painted,polished or altered) then they lose all there value and worth nothing>>>>>ED
