37 Master Deluxe Town Sedan Fuel Tank Removal & Replacement Advice Sought - 07/14/22 05:09 PM
I want to remove my original fuel tank so that I can take it to be cleaned, tested and repaired if required. I am seeking advice on the best strategy for removing and reinstalling the original tank while avoiding any known pitfalls. What parts I should have on hand if any of the originals can't or shouldn't be reused.
The tank looks sound enough from the bottom but has a minor leak from the sender area gasket at the top when overfilled. Some preliminary testing may indicate that the sender may be faulty, so I planned to have a replacement on had if the original can't be easily repaired. I have a new fuel line ready to install from Inline Tube once tank is reinstalled.
I've been running down the amount of fuel in the tank but not sure how far down I should go and what would be the best way to remove what remains. The drain plug looks a bit mangled so I'd welcome a picture of what it should look like or where a replacement can be found. I've yet to figure out how to attach photos in this forum but my damaged plug looks like it was originally a hex head with a standard screwdriver slot in the middle. Difficult to see for certain. I'm apprehensive to use a vise grip to remove it without having a replacement on hand. The car has the 216 inline six with a Rochester model B carburetor and I reckon that there could still be at least 4 gallons remaining in the fuel tank if I'm getting 10 miles to the gallon.
Thanks in advance for any wisdom you're willing to share.
