Advance Design Tie Rod Ends - 04/24/03 01:35 PM
I'm working on the tie rod ends on my 1953 3/4 ton. I disassembled one of the ends last night. A diagram from the shop manual is posted on my website at Tie Rod End Assembly to show you what I am referring to.
Looking at pictures in the shop manual, it appears that the only difference between 1/2 and 3/4 ton tie rod ends is that the 1/2 ton ball stud is pressed into the steering arm and the 3/4 ton stud is threaded and held in with a nut. The Master Parts manual gives the same part numbers for both 1/2 and 3/4 ton tie rod ends, except for the 3/4 ton ball stud. As far as anyone is aware, is this correct?
Replacement pieces are available for all of the interior parts of the tie rod end. However, the hole in the tie rod end housing, through which the stud extends, is pretty wallowed out on the edges ( a fuzzy picture is here ). Would the condition of this opening in the housing have a negative effect on the steering geometry? If so, does anyone know where I might get replacement housings that wouldn't be in as bad or worse shape than mine?
As a less desirable alternative (from an originality point of view), I know the vendors sell modern replacement ends which are one piece. All of the vendors except for Chevs of the 40s and Obsolete Chevrolet list the modern ends as being for 1/2 ton. Those two vendors list them as both 1/2 and 3/4 ton. Since I believe the original ends were the same except for the ball stud threading, I tend to believe those two vendors. Opinions?
Thanks in Advance. Keep on truckin'
