carb issues - 04/25/23 01:53 AM
I had my 28 chevy carb re-built
it ran great for a time , but now the float must not be closing
gas runs out the top vent hole
I have tapped on the bowl and carb itself and it will not stop leaking gas
I suspect that i have some junk in the seat? probably should take it apart and use a carb cleaner
at this time I am not using the gas tank , it was rusty and I will need to replace it
I have been filling the vacuum tank with gas to supply the carb
I cleaned out the vacuum tank, but it may have junk in it that I was not aware of
I suppose if I remove the bowl, and look for junk in the bottom , it may tell me the story?
it was running so damn nice!
thanks for the advice
Paul
Paul
