Rear axle shaft removal question - 11/28/22 02:04 PM
I need to replace the seals on my 32 Chevy rear axle and I need to know if there is a bolt / clip in the differential which must be removed prior to pulling out the axle shaft. I have never removed an axle shaft and I do know on later years models there is a bolt and C clip in the differential housing which must be removed prior to removing the axle.
