1930 Gaskets - Shakedown run leaks - 08/07/22 02:42 AM
So we flushed the block, installed a new sealed water pump, hoses, boiled the radiator/fuel tank and reassembled the car . It starts and runs beautifully, I ran it up and down the local hills with no heat issues. I'm super happy with impulsively bringing this car home last week. There are a lot of small issues to address but I'm feeling pretty good right now.
My primary issue is when I parked it I noticed I'm dumping oil from what looks like the timing cover. Drips following the car and a significant amount right under the bolt in the center of the cross member. After a short investigation it really looks like the cover is leaking. I dug through the parts book and found a number but am having no luck finding this gasket. Anyone have a source or am I stuck making one? Is there any other seals/gaskets in that area that may need attention?
Thanks,
Matt
Thanks,
Matt
