harmonic balancer - 11/01/13 11:13 PM
Replaced the original harmonic balancer on my 31 Phaeton with one that I removed from a 'wrecked' car. Old balancer was quiet at idle, the new balancer is noisy at idle (ugh!). 'New' balancer noise could possibly be caused by someone in the past removing/installing that balancer without 'bolting' the two halves together (as per user manual)before I found it.. I also have another 'spare' on the shelf. The original balancer looks different than the 'spare' on the back side as follows: On my original the springs that hold the two halves together are exposed and held in place by large washers, the washers are free to spin on the springs; they are 'loose', and they are located in a recessed area. (The 'looseness' is why I replaced the balancer) On the back side of my 'spare' balancer, the springs are not visible, there is a large metal cover that hides the four springs. Casting # on the front of the two balancers is identical, 836349. I just wonder if the original balancer with the 'loose' spring washers is safe for use on the car..., or if there was indeed several versions of the balancer used in 1931. Not looking forward to removing and installing balancer again. It took a lot of pounding to get it back onto the crank. My Phaeton is an early 31 with serial # xbae 1129, Vcca #18184
