Trying to figure out what is down inside the hole.
And, how far down in the hole did the piston sit at TDC? Was it basically deck height and all the volume was in the comb chamber?
Thanks,
Doug
Check the thread by BearsFan315 on his overheating problem. It's a 29 but will be quite similar.
There are some exceptions but most engine regardless of manufacturer the piston does not protrude above the top of the block while some dont come that high.
But how far down in the hole does the '33 piston sit while at TDC? Which is what I initially asked.
I am familiar with 50's and later motors. I know what deck height is, i know of high dome pistons where the dome is above deck height,and the "flat" part is say .035" down in the hole, the 350 HP, 327 for example..
But how far down does the '33 piston sit? 1/4"? 1/2", more?
Thanks,
Doug
The pistons in my 1934 Standard engine sit app.5 thou. down from the top of the block. This would vary slightly depending on how many shims have been removed.
The 1933 Master engine would be the same.
Original 34 Master. Hope this helps. Mike
The 1934 Master head /combustion chamber is completely different. Had the new "Blue Flame" combustion chamber in 1934.
