Ken 48 here you go,this could sound confusing and could be difficult with the wind lace and interior in...I think there is a cardboard pad over the location of the screws for the strap so I don't think you will be able to feel the holes
Measure from the top inter edge of the door latch striker to the inside edge of the door jam (straight but at an angle)14 5/8 inch..measure in from the jam (using a level)1 1/4 inch..this is the location of the bottom screw..the top screw is straight up 1/2 inch..hope this helps
