Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I would like to know the correct source for powering the radio on a 1954 pickup. Is it the same as a 53?
You may connect to the amp meter, which supplies power to the radio continuously, or to the ignition switch, which powers the radio only when the ignition is on. The second place to attach has the advantage of you not leaving the radio on and draining the battery.
Ray, thank you for that, I appreciate it.
Fred
