I have a shimmy in the front end of my 32, What is the correct amount of pressure to turn in the threaded end caps on the steering linkage as you compress the inner spring pressure on the inner ball cap ? Not sure I used the proper terminology, the end with the large cotter pin that has to be removed first.
1932 5 Window Confederate Coupe Best of Era 6 cylinder 2016
1968 Corvette Roadster 383 CI-425 HP
1938 Business Coupe "personalized"
The manual says to tighten until spring is compressed and rhen back off to the next cotter pin hole.
