Hi all,
I’m looking for the shift rod that changes the gear sets from R/1 to 2/3 if that makes any sense. It’s the rod that engages when you push or pull the shifter away or towards you on the column. The car is a ‘41 Special Deluxe, and I’m located in Asheville, NC. The piece was lost when the owner started a 235 swap last year, and he hasn’t been able to put his hands on it since. I’m sure I could make one, but I’d honestly just rather install one instead of making and adjusting one by trial and error.
Thanks in advance,
Reid.
