Posts: 190 Likes: 2
Posts: 190 Likes: 2 |
I'm replacing the back 3 windows in my 36 coupe, then my windshield next. What is the best product or compound to seal in the new glass. I'm using steele rubber so I want to make sure I do this right the first time.
Steele rubber recommends that CRL windshield and body compound, which never fully cures, it stays tacky. It's a butyl compound
I've used the tried and true 3m stuff, more expensive but I know it works. This stuff of course cures and does harden to some degree.
What should I use? Thank you
1936 Chevy Coupe. All Original
3M makes a product for that use. It is what I used years back with good results.
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
I don't think Steele would have switched to CRL from 3M if it wasn't as good or better. Just my thought.
Posts: 190 Likes: 2
It's a butyl compound instead of eurothane so it stays soft.
I'm in Arizona where it does get to 117 degrees. I've read that the crl stuff will seep out and get on the car.... not really what I want. So idk. I don't think GM ever used this stuff originally
Posts: 408 Likes: 10
Posts: 408 Likes: 10 |
I believe 3M 08509 is the old school non hardening type. Auto Body Tool Mart still lists it . Mike
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
I put windows in with windshield urethane. Never an issue ever.
Posts: 470 Likes: 33
Posts: 470 Likes: 33 |
I do not remember the part number but I used a 3M product when I put the glass in car. Normally if I am installing something like glass I just use whatever is recommended by the manufacturer. Especially if a warranty is involved.
