Posts: 3 |
I have a 51 Styleline Deluxe that had a seized engine which needed pulling out. I replaced with a truck engine of the same (Straight 6). It runs good but no reverse on this antique automatic. What do I need to do to to get working?
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Welcome to VCCA Chat. I'll put this in a technical forum for you.
The reverse band in the transmission is broke. Time for a transmission rebuild.
Posts: 3 |
Posts: 3 |
Chev Nut,
Will I need to buy a torque converter in addition to a transmission rebuild kit?
NO, It is not common for the converter to go bad. You will need a reverse band and link.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I would pull it apart and inspect all parts carefully then order replacements for anything worn or broken but a seal kit and reverse band would be on the top of the list Tony
