Posts: 5 |
I'm looking for a company that would have rear bearings for a 31 chevy Independence sedan. Any help would be appreciated.
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
The original New Departure bearing number for the rear wheel is 1307. New Departure became New Departure Hyatt and then Delco so you might find it in any packaging. I believe I bought mine from Locate Bearing. Brand new, clean and in new boxes. Hopefully they are still around. I have also seen them on ebay.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I found several on ebay ranging from $31 to $100. Google the bearing number and you'll find a lot of places to contact.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I believe the source Dave39MD referred to is : https://www.locateballbearings.com/ . I have used them with good success. As Tiny mentioned there are many sources however though the numbers may be the same you need to be sure the bearing is correct for your application.
