Posts: 9 |
Hello, can someone tell me what year chevrolet started using fiber timing gears on the small block v8? The car in question is a 66 caprice. thank you.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
My 1965 impala uses steel cam and crank sprockets , and a timing chain to connect the two. The gear drive timing gears may be an aftermarket product someone later has used in the 327.
JACK
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
All the Chev V engines I know of are chain drive cam where as the in line are a steel and fibre gear drive. I do know there are some after market conversions available here in Aus and guess some in the US as well. Tony
Posts: 402 |
I know Pontiac used nylon camshaft gears in 1967 though the early 70s as most GM cars. Ford used nylon cam gears as well.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
As Jack pointed out above, If there is a chain, they are not gears, they are sprockets.
The "nylon" GEARS WERE ACTUALLY THE CAM SPOKET had teflon teeth. As it aged the teflon chipped off. I do not remember for sure exactly which years had the Teflon but I DO NOT THINK 1966 HAD IT. THE REPLACENT GEARS DID NOT HAVE THE TEFLON teeth.
Generally by 100.,000 miles it wa advisable to replace the chain on either style.
