1940 & 1930 Parts - Refurbished Deluxe Steering Wheel with Horn button, NOS Horn Ring, Horn Ring adjusting bell, Steering Column Mast Jacket and Shift lever $ 350
Front & rear bumper brackets $ 40 -- Grill Guard (complete) needs plating $45
Vacuum Gear Shift Cylinder # 3654372 9 (appears to be NOS), Rubber Boot # 3654365, Used parts to complete system Metal Boot #3652646 With Shoulder Bolts, Lever Clamp # 591043, Linkage rods and Air Cleaner #1529302---- Plus 2 used Cylinders and other linkage, parts $75 -- After market Shift Linkage rod used to eliminate Vacuum shift system NORS $10 -- Shift unit at bottom end of Steering mast jacket $ 10 -- Brown Distributer cap NOS # $20 -- Gauges - Amp, Gas, Oil, Temp, $10 each --Speedometer $ 20 --Tune up parts AC Plugs AC 43-5 $24, Distributer cap (Black) $10, Points $ 20, Rotor $ 5, Condenser $ 5 -- NJ Title 4 Door Sedan $10
Call or E-Mail Dave Cavagnaro -- djcav@ptd.net - Cell - 908-319-3032 - Home - 908-362-5775
