#484277 08/12/23 08:33 PM
Shorty Offline OP
As I go through the forum reading everything, any time I come to something Keith Knox posts it says I am ignoring this person. Don't know how this happened and don't know how to correct it. Anyone know what to do? Thanks
So you are the one. Ha Ha. I don't post much here on the VCCA. But have been a member for over 20 years.
There used to be a way to "ignore" a person. I don't find that option any longer. You'll probably have to contact the webmaster to get it straightened out.
Shorty Offline OP
Yes Keith I am the one LOL. It has taken place for years and I haven't done anything about it. I probably miss some of your comments because all I get is the little strip at the top with no message. It has *** You are ignoring this user *** and if I see this and click on it I can read the post but it has a light gray overtone to the entire thing. Figured it was time to try to get it corrected.
Shorty Offline OP
Not sure if you will be able to see it but this is what I am getting.
Shorty Offline OP
Tiny,
Is that Peter that I need to contact?
Yes. I checked everything I could access and don't have the ability to help you.
From the member list or in a post click on the name
Just select Keith Knox and select view profile.
On the middle bottom right is the option to ignore or unignore,
It is a row of buttons.
They are not very bright buttons with the stock theme.
There is no such thing as stupid questions.
Just stupid answers.
Ruben that option is not there for me. It used to be there but disappeared some updates back.
Humm!!
it appears for me.
But I am a admin.
Let me check the permissions and may need to check with peter.
Shorty Offline OP
Thanks Tiny and Ruben. I think I have it taken care of. Not quite sure how I done it but it happened. LOL You have to click on View Profile to find it.
Tiny #484320 08/13/23 01:42 PM
Well many moons ago UBB stated that admins and moderators should not be able to ignore due to their job is to monitor.
Maybe it is turned off for moderators and for global mods all forums but they allowed admins now.
Tiny if you do not mind I can log in as you to test a few things.
But it will bump you off.
Scratching head.
Go ahead. Just don't be too amazed while you're "me". laugh
I am done looking.
You can log on again.
I will need to research it further in the scripts.
The last "script" I had to look at was for a play I was in......
This is probably a big thing so do not expect much.
As I said the mentality at UBB was never allow admins,moderators or global moderators to ignore a user because that was their job to accept all user posts to monitor.
Admins allowed to ignore is probably a bug in UBB's mind and should be removed.
