Hi All Recently took my 32 4 door for a drive and the part that holds the stick shift broke. Now my stick shift wonders and i can even pull it out. Need to know what part i need (name) to fix and where can I obtain one. Couldn't find it at the Filling Station. Appreciate any help.
not bad, yourself ? Thanks for asking.
The name is,,” seat , gear shift lever ball . Part no. 367407 “ They were made of die cast material which cracks with age. The retainer cap needs to be unscrewed to remove the stick shift, and replace the ball seat.
JACK
1 member likes this :
lbpuppy
Filling station part number is 367407 1932 to 1936
JACK
lbpuppy
I believe this is what you want but they are not marked with part numbers. If you think it is correct you can send me a private message and we will figure it out. Dave
I'll take a look tomorrow and double check to make sure. Thank you
This may help, from the 29-32 parts catalog. I got mine from the Filling Station. Dave
ball seat is what i need. the piece the ball sits in and then the cap (screw on piece) holds everything in place. cap is good, ball seat broke :(
