#479321 03/04/23 09:57 PM
rjp Offline OP
29,30,31,32 The bracket that bolts to the block and holds the spark cable that goes to the dist. The parts book no. 835689, Holds the spark cable for advance and retard. Thanks I am looking for one, thanks again
This photo is my 29, before restoration. I can probably get a better picture if you need one.
rjp Offline OP
Thanks I think I can make it out enough to make it work. Thanks again
a pict of 1929
I have a few of them. The one that is wire wheeled looks a little longer but it probably is bent a little different. If your cable is all metal I would buy some small loom and slip over it so it does not contact battery positive on the starter switch.
Let me know via pm.
