Posts: 112 Likes: 2
Posts: 112 Likes: 2 |
Gas gauge on my 31 Independence was erratic so I ordered a new float. Come to find it has two mounted on the rod. Is that normal or did someone retrofit it at some point?
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
It seems they came both ways not sure when the change was made. I have seen both.
I don't know when the change was made from the sending unit with two floats to the single float type. My best guess is early 1931. The former has a larger plate that screws to the top of the gas tank. The Filling Station sells replacement sending units. Be sure to tell them if the large or smaller plate.
Posts: 112 Likes: 2
The two cork floats were mounted on the rod in tandem. Both had dissolved almost entirely. Ordered the neoprene replacements from Spruce Aircraft. Much cheaper then the Filling Station.
