#471322 06/25/22 12:10 PM
THH Online Content OP
OP Online Content
Could someone give some guidance on what basic wiring I would need for a 207 first start. Just the basics.
Tom H.
THH #471330 06/25/22 03:59 PM
I assume that all you want to do is to determine if the engine will run.
You only need 3 connections.
One is a large (2/0) cable from the + battery post to the starter.
Another 2/0 cable attached from the - post to the block as a ground.
A 16 gauge wire from the + post to the coil.
THH #471333 06/25/22 07:03 PM
OP Online Content
Thanks Rusty. Should their be a wire from the generator to the battery?
Tom H.
THH #471343 06/25/22 09:15 PM
That is not needed to just start and run the engine. Just make sure the battery is charged pretty full.
