Posts: 1,049 |
any info about the camel back , double hump, 2.02 heads that would have come with a 1970 truck engine appreciated. i was told by an old timer that these heads i thought only came on corvette engine during 60's could be special order heads in 1970, kind of a z28 engine in a truck? thanks
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Ken, there is casting numbers and casting dates on top of the heads to help identify which heads they are, Commons double hump casting numbers end with 461 , 462, 186, 291, and 292,
JACK
Posts: 1,049 |
Posts: 1,049 |
Jack as a follow up the block has 3970010 casting number and the stamp on the passenger side ends TAX indication 1970 truck. The pan is off and its 4 bolt large journal. The heads number is 3991492 ( a 1970 number) and is the double hump variety. I was told and it appears that the block and the heads were factory. I pulled the camshaft out (solid lifters) and the size of the lobes was incredible. Needs replacement. Ken
Great Ken, sounds like a nice engine to have.
JACK
