#451488 12/08/20 12:16 PM
I have many sheet metal parts, fenders, cab, doors, engines (207 rebuilt, '36 rebuilt, 216, 235), transmissions, wheels (1 1/2 ton and 1/2 ton), frames, steering columns, running boards, other misc parts. Located Ca. What do you need?
ron
ron
Support The VCCA!
greencorn #451505 12/08/20 03:14 PM
PM sent
CarDC
VCCA# 52964
35 Chevy standard 3 window coupe
greencorn #451519 12/08/20 07:54 PM
PM sent
greencorn #453040 01/16/21 01:03 AM
Hi, I am looking for a 1936 steering gear clamp for my 1/2 ton, a world famous steering gear restoration shop lost it along with a not so great overhaul. I have been told that 33-36 truck and master car interchange
greencorn #457963 05/31/21 01:31 AM
Hi, I am looking for a drive shaft of a 1934 Stanard 6 2 door sedan. 10 spline, following the repair manual it is a D type. I hope you can help.
Regards
greencorn #457969 05/31/21 09:27 AM
The 1933, 1934 and 1935 Standaed drive shafts are the same.
Twostep #457970 05/31/21 10:14 AM
Sorry, I don't have that part.
ron
greencorn #458013 06/01/21 09:44 PM
you have any parts for 35 master?
greencorn #458038 06/02/21 08:52 AM
Probably have grill, head/tail lights, engine, wheels and other misc small parts.
ron
greencorn #458193 06/05/21 07:43 PM
Can you send me a couple pictures of the grill. 36 chevy coupe
1936 Chevy Coupe. All Original
greencorn #458418 06/12/21 07:03 PM
Do you have a driver's side tailight and mount for a 36 chevy? Thanks, Hendo
Hendo #458426 06/12/21 10:54 PM
Do you need it for a Coupe or Sedan?
Jon T.
greencorn #458436 06/13/21 04:10 PM
2 door sedan with trunk.
greencorn #458447 06/14/21 07:08 AM
I need a rear right fender for a 1947-1953 1/2 ton Chevy truck
greencorn #458448 06/14/21 08:40 AM
Sent you a PM
greencorn #461450 09/05/21 10:55 PM
Hi I need speedo housing on back of transmission 590791 that fits a 1936 master or 1936 pickup
Michael; did you get my message?
ron
ron
greencorn #461588 09/09/21 09:16 AM
You have a good 32 transmission ?
1932 5 Window Confederate Coupe Best of Era 6 cylinder 2016
1968 Corvette Roadster 383 CI-425 HP
1938 Business Coupe "personalized"
greencorn #463093 10/29/21 01:32 AM
Looking for spar tire cover for 1935 and interior door locks
greencorn #463099 10/29/21 04:46 AM
Looking for a right side trunk hinge for 1936 sedan with trunk.
greencorn #463219 11/01/21 05:13 PM
do you have an operational temp gauge? I'd take it.
zrupnick #463289 11/03/21 06:47 PM
I'll check tomorrow.
ron
ron
greencorn #463400 11/06/21 09:53 AM
Do you need the black face gauges or the yellow?
ron
ron
greencorn #463627 11/15/21 03:06 AM
Greencorn,
Would you happen to have any 1936 chevy headlight bezels? And the ring right underneath that holds the light in? I believe it's the retainer ring, if that's correct. I only need one of each
greencorn #464510 12/13/21 03:01 PM
Howdy,
Would have a headlight bucket for a 1935 truck? The rustier that better. I would take the entire unit as well if needed.
