Posts: 48 |
I may not be able to rebuild my original 216 in my 38 Chevy pickup. I have access to a 235 and I’ve been told they are very similar. Does anyone know if the motor mounts, clutch and transmission would bolt up the same? Thanks.
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
It can be done with attention to details. It is not a bolt-in swap. A big factor is what year 235. The original 235’s were based on the 216 block and used in trucks. Later 235’s were a different block.
Do your research to determine what special and additional parts you will need.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
Go the the Stovebolt.com. They have an extensive tech tip on how to do it. It is very doable. I rebuilt my 216s because I wanted to keep them.
I agree that Stovebolt is an excellent resource.
