#456992 04/29/21 08:46 AM
I’m new to the world of Chevs.
I’ve just acquired a semi restored 1928 roadster and am trying to work out what bits go where.
I really need advice on how the rear quarter panel is finished off to the rear (trunk) panel.
Both panels are nailed to the wooden subframe, but there needs to finishing strip to cover the gap.
All advice and photos appreciated.
Hi John,
I would highly recommend getting a copy of the Fisher Body Repair manual for these cars:
https://www.ebay.com/itm/1926-1927-...vice-Shop-Manual-Chevrolet-/353342882142
Based on your description, it sounds like the trim you are needing was a ~3/4" wide aluminum piece that was nailed down between the two panels to finish it off. Others in the form may have a good source for these, I ended up using a modern plastic trim piece with a similar profile, bedded it in epoxy and nailed it down.
-Tyler
Hi Tyler, Thanks...I’ll have a look around. Mine is an Australian body by Holden. I presume they used the same methods as Fisher.... Cheers John
Hi John
If your interested, I have a 1928 Chev roadster in Western Australia if you want to look at it. I am In the Armadale / Byford area.
Neil
9498 3829
Hi Neil,
Yes please! I’ll be in Perth next week. I’ll ring you to make a time. Cheers J
Like this black line?
Exactly! Thankyou for the pic. Just what I was looking for! Cheers J
If you cant find it down under, I think Restoration Supply in California carries it. Art
Thanks Art...
