Posts: 1 |
How is the door handle reset so that it is horizontal. My car is a four door and the two rear doors are fine but the two front door handles hang down just a bit and I would like them to be straight.
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
Try tightening the tapered screw that holds the handle in. I did it to my 37 and it helped a lot.
Ed
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
I believe that I recently read a post about replacing the spring. The old one did not provide enough force to make the handle return properly. Not sure if that is applicable to your car.
Posts: 1,894 |
You can buy latch rebuild kits from The Filling Station or Chevs of 40's. They have the spring that Rusty mentions as well as a bunch of other small parts. It's often the compound effect of minor wear on several parts that causes this sag. Drives me crazy.
