Wilson: I don't have a radiator. The rear motor mounts are fairly easy to rebuild yourself. Just pry the metal parts open and replace the rubber with any heavy belting material then squeeze the mounts back together with a vice. I've done this many times with good success. Don't spend a lot of money on having them re-vuclcanized.
I'm scared of breaking the metal and then having nothing! You are the second to tell me about doing it, so will likely give it a try. Maybe use some heat to soften the bend area? I'm thinking tire sidewall would be good rubber, with cords to help hold it together. Thanks, Wilson
Looking for the lower radiator apron with the two vertical pieces that attach to the radiator shroud. My painter has misplaced it and says he didn’t get this piece from me!
