#450511 11/18/20 03:10 AM
Has anyone replaced the outer door sill rubber covering on 1946-1948 Fleetmaster ? This is the ribbed rubber which looks like running board rubber. It appears to be bonded to flat sheetmetal which is fastened with small screws.
The original is cracking and breaking away.
I just want to know what I am getting into before I touch this as it looks like that old rubber will be disintegrating.
https://www.steelerubber.com/search...=fleetmaster&style=2-door-town-sedan
If this is what you are talking about. Should not be too hard, except for the $$$$. Good luck.
Russell #38868
'48 4 door Fleetline
They're also sold by Chevs of the 40s and The Filling Station
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
