Does anyone know what the size of the thread is on the clutch offset rod? I replaced the clutch plate and the rod is now to short to adjust the clutch as required. It works, but the adjustment is about 2 1/2 and with the pedal completely on the floor I can shift. I would prefer a more proper adjustment. I will attempt to use a couple nut and a bolt to extend the the length of the offset rod.
Paul
If it isn't broken, fiddle with it anyway so you have something to repair.
1931 Deluxe Sport Roadster
1953 BelAir 4 dr. Sedan
1965 Chevy II Nova SS
