Posts: 19 |
1936 Chevy 2-door Sedan -
Need Center Hood Hinge that holds the two top parts together would prefer original one but may need to weld on a replacement
Any ideas where to locate?
Posts: 654 Likes: 3
Posts: 654 Likes: 3 |
Ebay, swaps, Hemmings motor news, & junk yards are the places you will need to look at to find a rare part. You may have to buy a whole hood to get that hinge.
J Franklin
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I have just bought a new repo (had to wait while it was made) hinge for my 38 truck from Filling Station so they may have 1 to suit your 36 sedan. By the listing I will be welding it on when it arrives. Tony
Posts: 19 |
Thanks, I was curious if any other year or other car model would work. Because I am still building this car, I am guessing there is something that sticks out on both ends and that slides into the body parts to hold the top hood down?
Posts: 1,478 |
Yes there is. There are ends. One riveted to the front and the other bolted to the cowl. There should be two holes in the dip for bolts to pass through.
Posts: 105 |
Jim carter truck parts has an oem like hinge but it is on back order. I'm waiting for one for my 35.
Hainscou
Posts: 654 Likes: 3
Thanks The 1936 car hood hinge is an only year item and won't exchange with a truck hood hinge. My first answer is what needs to be done.
J Franklin
